vesc tool 1.25 not opening.
10 posts / 0 new
osis
good afternoon all hope you can help.
currently new to the vesc scene after buying a board from trampa and still waiting for my lipo's to be delivered, I was going to look at the software that is used to setup the vesc,
But the problem is i was on it the other night looking at it and went to open it tonight the program will not open i am greeted by a white screen followed by not responding in brackets top left of the screen next to vesc tool.
is there any recommend versions to run it as ? and possibly java to resolve this issue.
java is up to date and windows is all up to date as well running windows 10 pro 64 bit.  version 1903
many thanks,
matt.
That should not happen. Do you run software blocking things? Try to disable antivirus and firewall and see if it works.
Tobsor
Last seen: 10 months 6 days ago
Hi, did you fix that Problem?
Currently I have the problem aswell :/
Best regards and happy new year, ​
Tobi
marialoise
Also have this problem. Would appreciate some help please!
w31x
have the same problem with higher versions too. try ubuntu with the linux files working for me.
newvesc
Same problem (vesc tool crash / CTD) on 2 computers Win10 Pro 64-bit, 3rd computer with Win 10 Pro 32-bit runs fine.
Access Violation errors/problems reading memory seem to be cause.
oger
Last seen: 4 weeks 19 hours ago
Same problem here.
with 2.03 exe
Any ideas?
Mac Motor
newvesc
Now it started crashing on the computer it worked on to.  Was spare and reinstalled windows and it still crashes, not shure why so...
osis
nope, i have added it to firewall, disabled antivirus,  and other things and still nothing
it works on a crap laptop that runs windows10 64bit fine,
does not like my gaming rig what so ever, i even tried it on a clean install and nothing when i needed to format.
flyingbrike
flyingbrike's picture
sudo ./vesc_tool_3.00
Silent Revolution is NOW !
