missing Analog Throttle failsafe
bosko
im user of VESC 4 and here is my setup.
im using ADC + UART
I use Analog Throttle (ADC1 , 3.3v, GND)
I use Bluetooth (5v, GND, TX , RX)
When i power VESC all is good, motor spinning, but when i remove Analog Throttle from VESC, motor rotate with FULL SPEED.
Is there any FAIL SAFE for that ?
I want to STOP MOTOR if i remove Analog Throttle jack not to FULL SPEED.
Last seen: 3 months 1 day ago
you should add pullup resistor on the adc input to stop that happening.
bosko
hi @TechAUmNu im new in this, tell me is it like this. What resistors i can use for this ?
Last seen: 2 days 2 hours ago
A pull down is probably what you mean :-)
The resistor between ADC and GND should be enough. A value of e.g. 10k should work.
Yes I meant pull down!
bosko
Thanks, i will do that
