Hello! I've been playing with a forked version of the vesc-tool and just found an easy way to add HM-10 compatibility alongside the NRF chip which is currently supported. The NRF chip is superior since it can operate at 115200 Baud and I find the HM-10 is stable only to 19200 Baud. I'd make this a pull request, but code is forked and now head is a few commits in front, also the changes are minimal so I'll just outline here. The key thing I found that made this easy was an AT command which creates adds a second characteristic to the HM-10 service UUID. You will need to access the hardware serial of your HM-10 module and send the following AT command (thorough guide here):
AT+FFE21While your at it you may want to set your BAUD to 19200 to maximize data rate with the following AT command:
AT+BAUD1The service UUID is different for the HM-10 as compared to the vesc-tool so there's a couple snippets that need to be added to bleuart.cpp to try both UUIDs. First I create to UUIDs to try:
mServiceUuidtry1 = "0000ffe0-0000-1000-8000-00805f9b34fb";
mRxUuidtry1 = "0000ffe2-0000-1000-8000-00805f9b34fb";
mTxUuidtry1 = "0000ffe1-0000-1000-8000-00805f9b34fb";
mServiceUuidtry2 = "6e400001-b5a3-f393-e0a9-e50e24dcca9e";
mRxUuidtry2 = "6e400002-b5a3-f393-e0a9-e50e24dcca9e";
mTxUuidtry2 = "6e400003-b5a3-f393-e0a9-e50e24dcca9e";These new variables will also need to be declared in the header file.
Then the service discovered method just needs a slight modification to check both possible services:
void BleUart::serviceDiscovered(const QBluetoothUuid &gatt)
if (gatt==QBluetoothUuid(QUuid(mServiceUuidtry1))){
mServiceUuid = mServiceUuidtry1;
mRxUuid = mRxUuidtry1;
mTxUuid = mTxUuidtry1;
qDebug() << "BLE UART service found!";
mUartServiceFound = true;
if (gatt==QBluetoothUuid(QUuid(mServiceUuidtry2))){
mServiceUuid = mServiceUuidtry2;
mRxUuid = mRxUuidtry2;
mTxUuid = mTxUuidtry2;
}Cheers,
Jeff
I wrote this without much formatting and then went back to edit it. I select the commands (one at a time), hit "quote" to make that single line into a quote to distinguish it from the rest. When that doesn't do what it does in 1000 other editors. I'm sorry, but you're left with a mess.
you might be able to do someting with git. Something along the lines of:
git remote add vedder <url of vedders repository>
Now
and assuming that your repo is setup to follow your own github stuff,
Hi Jfriesen,
i bring this topic back to top :)
I tried to modify my vesc-tool sources in your way to use the hm-10. i compieled well, the hm-10 is detected on the bluetooth le tab, but i can not connect to the vesc.
Debug Output:
qt.bluetooth.bluez: Missing CAP_NET_ADMIN permission. Cannot determine whether a found address is of random or public type.
DEBUG (../vesc_tool/bleuart.cpp:137 void BleUart::addDevice(const QBluetoothDeviceInfo&)): BLE scan found device: "HMSoft"
WARNING (:0 ): Enabling GATT request timeout behavior 20000
DEBUG (../vesc_tool/bleuart.cpp:154 void BleUart::scanFinished()): BLE scan finished
WARNING (../vesc_tool/bleuart.cpp:213 void BleUart::controllerError(QLowEnergyController::Error)): BLE error: QLowEnergyController::Error(UnknownError)
WARNING (:0 ): void QBluetoothSocketPrivate::_q_readNotify() 27 error: -1 "Die Ressource ist zur Zeit nicht verfügbar"
DEBUG (../vesc_tool/bleuart.cpp:226 void BleUart::deviceDisconnected()): BLE service disconnected
The modified code ist not executed, my in the serviceDiscovered function is not reached..
do have any hint for me ?
any news?
any news?
my Problem was the baud-rate. The HM10 is too slow for 115200, with 9600 everyting works fine
Georg
