Where to connect the Button for Reverse driver?, in ADC mode (Ebike throttle)
Astropower
Hello Everyone,
I have renew a old Electric ATV for Kids, i took out the old motor, and i put 70KV 80100 Outrunner. Which connected to 48V 30Ah (120A Peak) Lithium Pack.
The VESC6 software works fantastic.
I dont know where to connect the reverse driver button ? Which port it belong too ? ADC2 ?  and should i give 3.3V or 5V or just GND signal ? to where?
Thank you in advance.
Astro
hackish
I'm in the same boat as you. I've put some larger motors in my daughter's electric jeep and am  building a variable throttle pedal so it doesn't strip the gears. Unfortunately there is very little information available about the reverse button. Did you manage to solve your problem?
Last seen: 1 week 6 days ago
Reverse button should go on RX pin. The pin has a pull up so you just need a switch to pull it to ground.
hackish
Turns out in my case that the reverse button actually goes on the PWM pin. Is this a difference in the VESC 4 and VESC 6 hardware?
