VESC 4.12 - Data loss on power off
da_rul0r
Hello guys,
is it true the VESC 4.12 will lose its saved configuration parameters once you unplug it? I also read (offline) that this can be prevented by using the Vedder SparkProtection switch as it upholds a small voltage after it is turned off (I tested this with a multimeter on a Sparkprotection 1.3, but the voltage in off state was just about 0.02 V). Is my information correct?
Thank you very much.
Addy
No, the VESC 4.12 won't lose configuration parameters when power is removed. I have been using VESC 4.12's on two ebikes for nearly 2 years now, neither one of them has forgotten the configuration.
da_rul0r
Hi Addy,
thanks a lot for your answer.
