VESC FW 3.56 Support download?
bluesywalnut
Does anyone have an older version of the VESC Tool that has support for FW 3.56? My Flipsky 4.12 single VESC is on FW 3.56 and I can't update the firmware for whatever reason.
Mangirdas
I have firmware 3.52 and I can't configure my vesc just because I get firmware error (3.57 is available). But I can't update it either via Bluetooth or UART. It just gets into same state :/
@benjamin any ideas?
If it doesn't do anything after you upload the firmware and you have to manually reboot it. Then it comes back with the old fimware again. Then you either need to flash the bootloader or you have broken the bootloader.
Go to bootloader tab and upload the bootloader first.  The Bootloader tab is in the firmware menu, top of the window.
ipbyrne
Hello Frank,
I have installed the bootloader but am still having the same issue. After the update, the firmware is still 3.5 instead of 3.58. Is there anyway I can just get a version of the tool that works with 3.5?
