half speed on FOC vs BLDC
ever.summer
Hey there!
I have been running BLDC for a while now and getting up to 43kmh but I just switched to FOC and I cannot get a speed above 18kmh.
My setup is the Flipsky 6.6+, dual motor control. The duty cycle is hitting 95-100% and I have tried programming for medium and small motors, and also programming with and without the timing belt installed. So far, still getting this 18kmh speed limit. I saved the settings and according to the mobile app the max speed is 87kmh so I don't know why I'm being speed limited.
Would truly appreciate any ideas out there!!
thank you!
ever.summer
sorry also should note I am running sensorless system and programming from the mobile app
ever.summer
argh, nm... I knew it was a dumb mistake and I was right. Got it all figured out now...
bgdwiepp
Last seen: 12 months 2 days ago
What was your mistake? You should post what it was regardless.
https://xkcd.com/979/
ever.summer
@bgdwiepp - I forgot that the KV was cut in half on the new set of motors I am testing
