No firmware listed, after DRV repair
anymorez
My VESC is after DRV8302 replacement, because I shorted outputs when running engine. I corrected all pins seperately, they are connected neatly and properly to PCB now. Blue and green LED are on.
VESC tool connects to the device on limited mode (old firmware windows pops on on connection, and recommends to upgrade). When I go to firmware tab I see no firmware's available on the list, and whatsmore in this tab I can't connect to the target although I am actually connected to device, I see connected (limited) in right bottom corner.
My question is how can I get rid of this limited mode and operate normally?
Dillon
Last seen: 3 days 19 hours ago
Have you tried flashing the device with an ST-LINK?
