Easy way to save VESC parameters before updating FW with VESC tool ?
unimotion
Do you know if there is an easy way to save Motor and App setup before updating FW so that the initial parameters can be reloaded after FW update, to avoid having to begin again setting VESC up ?
I tried to use file save and load configuration XML but it looks like some parameters are not saved (or loaded) and one has to review completely setup.
Sorry if this question is not relevant I'm a new user even if a big fan of VESC project.
unimotion
Just tried to use save and load config XML for motor and appli and it worked, it looks like all parameters were correctly saved and reloaded,
so this post is closed, thanks !
