Support for AMC1301 powered from bootstrap
antonchromjak
Last seen: 1 month 4 days ago
I made custom board that has AMC1301 powered from mosfet bridge driver. Problem is that when start it calibrates current without AMC1301 powered and then it reports invalid currents. I tried power all AMCs from battery with diode and it worked without problem. I think this should by fixable by software.
Is it possible to make some extension that will at freewheel operation switch one lower mosfet ON? This should power all AMCs.
I tried some changes in code but I only keep blow fuses.
Thanks,
Anton
antonchromjak
This helped. But I'm not sure why. Any suggestions?
static void stop_pwm_hw(void) {
    #ifdef HW_HAS_AMC
        TIM_SelectOCxM(TIM1, TIM_Channel_1, TIM_OCMode_PWM1);
        TIM_CCxCmd(TIM1, TIM_Channel_1, TIM_CCx_Disable);
        TIM_CCxNCmd(TIM1, TIM_Channel_1, TIM_CCxN_Enable);
    #else
        TIM_SelectOCxM(TIM1, TIM_Channel_1, TIM_ForcedAction_InActive);
        TIM_CCxCmd(TIM1, TIM_Channel_1, TIM_CCx_Enable);
        TIM_CCxNCmd(TIM1, TIM_Channel_1, TIM_CCxN_Disable);
    #endif
    TIM_SelectOCxM(TIM1, TIM_Channel_2, TIM_ForcedAction_InActive);
    TIM_CCxCmd(TIM1, TIM_Channel_2, TIM_CCx_Enable);
    TIM_CCxNCmd(TIM1, TIM_Channel_2, TIM_CCxN_Disable);
    TIM_SelectOCxM(TIM1, TIM_Channel_3, TIM_ForcedAction_InActive);
    TIM_CCxCmd(TIM1, TIM_Channel_3, TIM_CCx_Enable);
    TIM_CCxNCmd(TIM1, TIM_Channel_3, TIM_CCxN_Disable);
    TIM_GenerateEvent(TIM1, TIM_EventSource_COM);
#ifdef HW_HAS_DRV8313
    DISABLE_BR();
#endif
    m_output_on = false;
antonchromjak
