SK3 Turnigy 6374 149 / encoder CUI AMT102 => can VESC 4 support position control?
fourchette
hello,
I have the following motor and quadrature encoder
motor: areodrive turnigy SK3 6374 149
encoder: CUI AMT102 (it's a quadrature encoder with a 2048 * 4 ticks per revolution)
on a VESC 4 board
Can i get position control throught UART with this?
thanks
pf26
Last seen: 2 months 10 hours ago
Yes. Beware you need up to one turn to have the encoder index found, and your absolute motor position is not determined until then.
fourchette
perfect. this limitation is perfectly fine.
unfortunately i do not have my VESC 4 cards nearby, thus vesc_tool wont start its excellent motor config wizard
in previous setup i was using velocity control over UART using hall effect sensors and foc.
here looking i settings windows i see
Motor > General > General > Motor type > FOC (is it ok?)
Motor > General > General > Sensor Port Mode > ABI encoder / AS5047 encoder / AD2S1205 resolver (which one should i choose?)
Motor > General > General > ABI encoder count > 8192 (looks like a 2048*4 so should be ok, can u confirm?)
Motor > FOC > General > Sensor Mode > Encoder
Motor > FOC > Encoder > Encoder > Encoder Offset > 180.0 (should i keep this default value?)
Motor > FOC > Encoder > Encoder > Encoder Ratio > 7.0 (what is this?)
Motor > FOC > Encoder > Encoder > Encoder Inverted > False (what is this?)
Motor > PID Controllers > Position Controller > Kp / Ki / Kd / Kd Filter ==> please tell me i do not have to touch this and the wizzard will take care of it???
Motor > PID Controllers > Position Controller > Position Angle Division > 1.0 (what is this?)
in terms of cabling the encoder, is it like hall effect = dont care about how things are connected, because the wizzard will figure it out alone? or do i need to follow a particular convention?
Now for controlling the position, it seems the API is to talk in degrees instead of encoder counts (which is fine). So on principle issuing the following commands :
+360 makes the motor turns one complete revolution in positive direction
-720 makes the turns spin backwards 3 revolutions
0 makes spin forward 2 revolutions
0.5 makes the motor spin forward 0.5/360*8192 = 11 encoder ticks
and what is the best way to make that single turn to have the encoder index found? (calibration i suppose)
(ok maybe there are too many questions here... but the i did not find enough explanations in the manual => https://vesc-project.com/node/180)
pf26
Cabling:  A, B and I (on Hall input 3)
Then please give it a try, and ask more questions if needed.  I fear position control is not multiturns (at least it wasn't at first) -  maybe it can be done with some parameters like position angle division ?
fourchette
What???
Limited to single turns??
Can't be. What if there is a 30:1 gear reduction after motor?
We'll see. I'll try and report. Isn't VESC opensource? Maybe if default FW limits absolute positioning to single turn someone can add support for multiple turns?
pf26
I think someone already developed a multi-turn firmware patch: see https://vesc-project.com/node/626
