VESC 4.12 problems with FW newer then 3.10
muchtete
I am having trouble updating my original VESC 4.12 to a newer Firmware version (desired version is 3.31).
In short: Updating the firmware over the VESC-tool or through flashing the newer firmware directly on the chip with an st-link, results in no led blinking and the VESC not being recognized as USB-device and consequently not being able to connect with VESC-tool -> basically bricked.
I wanted to update the FW, using the VESC tool. For that I connected and powered the controller over USB with no further hardware or power supply attached. After making sure HW-version matches I updated through the tool which went through without any error. After the update was done, the problem occurred as described above. I thought the chip was bricked. Connecting a st-link and flashing the desired firmware as well as the bootloader (flashing the chip worked fine, no errors during the process) didn't change anything.
After trying to work this out a whole day, I tried flashing older FW-versions. I found that up until version 3.10 the controller seems to work fine, with the LEDs showing the usual start-up routine and the controller being shown as usb-device and being able to connect to in vesc-tool.
The problem with updating still exists nonetheless.
Could there be a problem with powering the controller over USB only?
I have no idea what could cause this behaviour. Any help or suggestion is appreciated.
Kind regards,
Niels
ravenswood1955
Last seen: 6 months 4 weeks ago
Same problem but all I got was I had old firmware. I would go through the motions for update, even the controller was flickering like a data transfer was occurring. reconnect and reboot only to find still had the old firmware. I tried drivers,cables,other programs, Enertions BLDC bla bla bla. I thought I got around this when I flew drones, you know that darn learning curve. Cant offer any help, sorry. I guess some day Ill figure this out.
john steffens
GunnarW
If you have not seen this thread already, read it. Some of us including myself seem to have solved their problems after reading it:
https://vesc-project.com/node/175
I would like to see a thorough instruction on how to do these things to avoid the ongoing troubles we, not so knowledgeable people, have. And some advice about when we should update our soft- and firmware even though our motor works. Or is it just "if you at last got it to work don´t touch it...ever". I mean surely there must be some benefit, even to us to update, from the outstanding knowledge and time Benjamin put into this project.
