VESC 6 Schematic Question
9 posts / 0 new
mendez
Hey Guys;
What is U11 in the schematic? and which model for the MOFSET (IRF7749) would you guys recommend?
Thanks for the help!
Last seen: 1 week 2 days ago
Hall sensor.
mendez
P4 is for the Hall Sensor. But U11? The 1, 2, 3 seems to be a switch right (used on the hallsensor)?
sam.vanratt
Hi mendez
the U11 is a switch symbol, meant to allow switching of the supply voltage for the HALLs, PullUp resistors and temp sensor. Nowadays all HALLs I know of work with 5V (min Vcc=3.6-4V), but maybe with Die-Shrinking the Voltage will go down to 3.3V in the future. The used uC is 3,3V and accept only voltages up to 3,3V, so running every input with max. 3,3V is very tempting.
Cheers
Sam
copetresillian
Last seen: 7 years 1 week ago
I think it's  hall sensor.
Pimousse
The switch allows the use of encoder working with 3.3V.
dreydean
Why is the MPU9150 SCL and SDA lines tied to the bluetooth RX and TX lines? The mpu9150 requires pull up resistors to 3.3v so this doesnt seem like a good idea?
Drey Platt
dreydean
Anyone know if this is a design error. It appears you either can have an accelerometer with pull up lines or a bluetooth module, not both.
Drey Platt
Which HW are you talking about? The VESC 6 plus?
