PPM Mislabeled
stevemk14ebr
PPM Mislabeled
Why is the PPM port on the vesc not able to decode PPM, and instead only works with PWM? It is very unclear if PPM is actually supported.
Last seen: 1 year 1 week ago
PPM just like PWM is a quite general term that does not completely describe the signal you are talking about. Can you point to a document that describes the PPM that you would like to have supported?
