position control with gearbox
20 posts / 0 new
raess
I need some help :)
I have a 3D-printed actuator with 6:1 gearing. The position control works great, but since I gear it, I only get 60 degrees range of motion. Would it be possible to control on the encoder steps? or how can I get 360 - degree motion?
btw: here is the actuator
Many thanks
Robin
arvidb
You should be able to get more than 360° of motion out of your motor (to make your gear output move 360° or more) but the VESC can't handle position steps larger than 180° (I guess this is a bug in the position PID routine - it uses utils_angle_difference() to compute the error angle and that function always returns a value between -180° and +180° when I guess the error should be based on the actual multi-turn difference between set and actual position).
So if you feed the VESC multiple smaller moves, always within 180° of the current motor position, it should work. I haven't tried it, I'm only looking at the code.
Or change
	// Compute parameters
	float error = utils_angle_difference(angle_set, angle_now);
to
	float error = angle_set - angle_now;
in mcpwm_foc.c.
Wait, maybe the encoder code doesn't keep track of multiple turns. Then the above won't work and I guess you are out of luck. sad
wdaehn
We had a similar discussion in the past and the conclusion was that "Servo Control" and "Position Control" are two different things. Vesc supports Servo Control only, so an angle of 180° per call.
"vesc supports" is a bit easy... Current vesc firmware supports... would be more accurate.
What you could do is to have an "app" running that will feed the main vesc code a "carrot" position depending on the wanted multi-turn final position. The thing is that the PID loop can and should be adjusted to be able to stop in half a turn. So when you set a target that is say 100 turns away, at position 50.0 full turns you're still feeding the PID loop something like: "Please go to 50.49" which it will try to achieve with the condition that it can STOP there. What it (the PID loop) doesn't know is that once you reach 50.1 position you'll adjust the target to 50.59.....
wdaehn
(Correct, yes, the firmware is the limiting factor.)
Yes of course that will work. But how would you do things like speed ramps etc? All is theoretically possible but not from a practical point of view.
And if my understanding is correct, the servo mode will not have the same torque at e.g. 1000rpms. Servo mode is forced commutation, isn't it?
Either way, desperately waiting for the VESC to support proper positional control including speed=0 downhill.
raess
Thanks for the answer guys. We are looking on how we can update the firmware to support multi-turn position control. The current position control will not work for our use case.
We tested the Odrive position control which allows control with encoder counts:
https://www.youtube.com/watch?v=qHH8VnjDOFo
wdaehn
You tested ODrive and the result was....?
raess
The result was great. I can control the motor on encoder counts.
So for the AS5047P 4000 count/rev. I can send it +- 12000 counts and get 360degress on the output on the gearbox.
Lets see if we can modify the VESC firmware to have the same control function.
raess
Some more testing with odrive
raess
Okej. We are working on implementing multi-turn position control for the VESC. We already got it working more or less.
Now the encoder handles multi-turn postions and we do no longer compute shorted angles , we use full revolutions.
The encoder position still remains degrees and not encoder ticks (so it remains back-compatible) with existing commands.
The vesc tool need to be modified to allow greater degress then 360 in order to control bigger degress from vesc tool interface. We are running Pyvesc for dev.
raess
So here is a quick video on the gearbox output. Using 0-2160Degress control.
raess
So we need some help,  for example, how is the ERPM used in the actual foc position controller? and how could the ERPM be changed at motor running time?
raess
We are working hard this weekend to implement a cascaded style position, velocity and current control loop in the VESC firmware. Now we can control multi-turn positions with speed settings. Nice!
raess
We made a simulator for this new multi-turn cascade position control so everyone can see how this modified VESC firmware works ( http://grauonline.de/alexwww/motorsim/motorsim.html ) - Happy controlling
raess
Motion testing over ROS.
arvidb
Yeah, a cascaded controller seems like a good idea. Have you published your code somewhere? (Your site seems to be down.)
raess
Yeah, my site is down at the moment. But you find the modified FW here: https://github.com/raess1/vesc-FW
Also have modified PYvesc and Ros driver under my git.
Cheers
Magistr1018
Last seen: 4 years 1 week ago
I have a task:
I developed a gear motor, installed the encoder on the output shaft.
It turned out very compact and high-torque!
motor thickness is 20 mm, diameter 70 mm - moment 0.5 Nm.
the reduction factor is 99 and it takes up to 10 A.
I need help in compiling a project on a 15 bit encoder !!!
Schem
IanG
Hi raess!
I have the same situation with you, so I really appreciate you made the VESC achieve the multi-turn. But I still have some questions. Now I am using FW4.2 and want to achieve that in FW4.2, so can you clarify more details about your codes? which and where the code are changed by your effort? THX!
IanG
Artabotak
Artabotak's picture
Hi mate its working with vesc 6?? 75100??
Artabotak
