FFT in VESC Tool
RSR
Last seen: 3 weeks 17 hours ago
FFT in VESC Tool
The reported frequency of a signal varies PWM frequency and sampling mode.   Is this a bug?
How to reproduce:
  1. Connect motor, power, PC, start VESC Tool and tune FOC operation
  2. Enable "send alive packets" -- heart-symbol on right toolbar
  3. Type in VESC terminal:  foc_openloop 20 6000
  4. Sampled data:  press sample now, and show FFT Plot and zoom the plot to see a peak at 6000/60 = 100 Hz  (but in my case the peak is at 133 Hz)
  5. Repeat with other settings of Motor Settings --> FOC --> Advanced --> Switching Frequency  (and observe that the measured frequency changes)
  6. Repeat with other settings of Motor Settings --> FOC --> Advanced --> Sample in V0 and V7  (and observe that the measured frequency changes)
I used VESC Tool Original 0.94 for Windows (but this is probably consistent in other versions)
Last seen: 2 months 14 hours ago
You would expect the frequency to change when you change those settings. What do you mean by "reported frequency of a signal varies PWM frequency and sampling mode"?
RSR
@TechAUmNu:  This might me obvious, but when I make FFT of a 100 Hz sine signal, then I expect to see a peak at 100 Hz (and not a 50 Hz, 133 Hz or 200 Hz).
The command "foc_openloop 20 6000" requests the VESC to output 20A amplitude sine at 100 Hz, in each of the 3 phases -- regardless of PWM frequency and sampling modes.
The reported (measured) frequency is the location of a peak in the FFT-graph of measured current.
Those settings should NOT change the current frequency (they only apply to PWM and sampling frequency).
Ah I see what you mean now. Yeah it shouldn't change. So something about foc openloop or how it generates the signal is time based on the rate the observer runs at.
