Touchy ADC Connector
ebikerevolution
Hi there,
Relatively new DIY eBiker here. I'm providing current to my motor using a hall-sensing throttle on ADC (3 wire: 3.3V,GND,Signal). However, once everything is set up and written to the VESC, the connection between the throttle and VESC is very touchy. Any physical movement makes the motor spin up. This is a definite safety issue, so does anyone have an idea for a fix to this?
Best,
EBR
If the physical connection is flaky, there is not much you can do but to improve it.
If it is that it is very sensitive to start, you can tell it to remain at zero for a range. That is done in the ADC app configuration page.
