What's the PCB dimension of the VESC 6?
darwinbeing
Hello everyone,
         I am currently working on desgining a VESC 6 pcb,  I want to know some information about the VESC6,  for instance PCB dimension, trace size, via size.
Any help would be appreciated!
VESC 6 - With NRF (EU CUSTOMERS) Premium Silicon cables, XT90 connector & 3.5mm Gold plated Bullet Connectors for Underboard Battery tray
Last seen: 4 weeks 2 hours ago
If you have the knowledge to make your own PCB, why does it have to be an exact copy? Doesn't it make more sense to make your own design with e.g. a different form factor, different power levels or different voltages? The VESC6 is one of many possible designs, and there is no reason to make something that looks the same unless you intentionally want to confuse customers...
darwinbeing
OK,  I SEE.
