UART GND to Battery (-), good idea ?
Pimousse
Hi guys,
I wasn't sure about the right place to put this. Sorry if I'm wrong.
I'm trying my best (but far away from your skills !) to build my own PCB for animating a battery gauge and rearlight and frontlight management.
Until now, everything worked perfectly on the breadboard and I'm working now on the frontlight high power LED.
I plan to use LDD-700H LED driver controlled by PWM. But for this purpose the reference of the PWM signal has to be the Vin(-) of the driver, so the battery pack (-).
But I'm also communicating through UART with the VESC. So that means the GND of my Arduino is connected to VESC GND and thus connected to battery pack (-).
I'm not sure it's a good idea and don't want to create a kind of current "loop" that could fry the VESC 6.
You, electronics gurus, what do you think about it ?
Electronics scheme and PCB : https://easyeda.com/Pimousse/PirCac_Onboard_copy-f811f25c73e54b08bc6f309...
Thank you very much.
Dillon
Don't do that. Use a solid state relay capable of switching fast enough for your needs.
