I want to connect my throttle to my vesc but it won't work it keeps giving me 0v
Don't attack me
Hello everyone!
I recently bought a spintend ubox 100v 100a
And I want to connect a pas sensor and a throttle and they both give me 0v they are just basic aliexpress throttles commonly used on fatbikes and other chinese bycycles the name of the connector is higo julet mine are 3 pin and I wired red to 5v black to gnd and blue to adc1 I tried swapping out the cables with no succes and I tried to use different clamps or just manually wire them together no matter what I did the vesc software didn't read what it should have I also tried 2 different throttles and even lisp scripting but I couldn't get it work work anyone had the same issue
yuinogitai
Is it possible your throttle signal voltage is wrong? VESC ADC pins are strictly 0–3.3V – have you measured the signal wire with a multimeter?
YUI
