I need help with VESC Tool 6.06.
The issue: The software used to work perfectly on my setup. However, it has now stopped opening entirely. When I click the icon, nothing happens. I have tested this on multiple laptops, and the result is the same across all of them – the application simply won't launch.
Technical Details:
File:
vesc_tool_6.06.exe(File size is showing as 165 MB).Icon: The file display has reverted to a generic Windows white icon instead of the VESC logo.
System: Windows 11pro.
Hardware: Flipsky FSESC 4.20.
I noticed that the official website is currently showing PHP errors (
Notice: Undefined offset: 1 in _uc_file_download_transfer()) when trying to access the download section.Has anyone else experienced this sudden failure? Could the 6.06 Windows binary be corrupted or incorrectly bundled?
Any advice or a link to a stable 6.05 version would be greatly appreciated.
Thank you.
VESC Tool 6.06 - Used to work, now won't open on any PC
Thu, 2026-05-07 14:37
#1
Vesctool is best treated as.a exe file . Before trying go to task mgr and check disk it should be under10%. If not switch the oc completrly off and back on. Check task.mgr and if not underv10% leave fir an hour and check. Once this done anx you have removed any vesctool in the task mgr try opening vesctool.exe.
john smith
