Problems with FOC, duty cycle and current
Laurasiaac
Last seen: 5 months 3 days ago
Hello to all!
I have to finish a college project and I am desperate, to say the least, to make the motor do something, ANYTHING!
I have a battery pack 10S that altogether make 40V
a VESC BLDC MTVESC50A - 50A Fw now v5.03, Hw  410
a brushless motor
When I try to use it in FOC mode it right away shows fault_code_high_offset_current_sensor_1
When I change to BLDC, which I'm fine with, it behaves in a weird way. If I  send a current of whatever amount of ampers, duty cycle immediatly reaches 95%, the current starts to oscillate from a number between 1 and -1 (never reaches the value tho:
If I set the DC at, for example, 0.2, the current oscillates from -6 to 6A.
but the motor of course, never rotates. Detection of BLDC and/or FOC parameters always fails.
The thing is that 2 weeks ago everything was working perfectly.
Is anyone able to shed some light?
Thanks,
Experiment to see the behaviour:
Supposed to perform a current sweep from 0 to 10 A, step 2 and over 2s
Laurasiaac
This is the only component that seems to be burned.. But I'm not sure
L-
