Pronto Starting problem LED blue blinking
zig68
Got a Pronto when starting well which works fine with connecting pin 28/29
Once we use a shut down, the restart is not able right away.
Blue LED is blinking non stop fast.
once restart after a waiting time - 5 min approx even more. Can not load any mistake on the VESC through the terminal.
Thanks for your help.
electricfox
electricfox's picture
Last seen: 12 hours 39 min ago
Update firmware in Firmware->Archive-> click Download/Re-download Archive-> select HW Pronto -> click the button (arrow down) "Update Firmware on the connected VESC" This will solve your problem.
zig68
Hi Oliver,
thanks very much for this prompt answer.
Everything works fine !!! smiley
We still would like to understand the issue so we have a clew on the problem.
Was is a bad flash firmware when we got the PRONTO as I did only proceed to a full re-write of firmware and configuration ?
Thanks for your feedback
JP
k2.sailboat@gmail.com
cheers.
electricfox
You are welcome! There was an issue with the firmware, which was solved. With downloading the latest version of this firmware you got the fix. Enjoy your Pronto!
