Flipsky 75100 pro v2 ADC throttle stopped responding
JozoBozo
Last seen: 3 months 21 hours ago
Hello guys, I have the 75100 pro v2 vesc on my e bike with a hub motor and a twist throttle that stopped working and the voltage stays at 1.47v in setup input tab in vesc tool even though i get 5v between gnd and the 5v wire and a range of 0.8v-4.2v between gnd and signal (ADC1) wire like i did when it was working but still no changes in setup input?
mariuszdymon
Last seen: 3 weeks 5 days ago
try reset only app setting default  . maybe your max pin adc voltage is 3.3v and you overloaded by giving 5v .
check the wire connection
JozoBozo
Yes I'm a dummy, it's for 3.3v and i had the throttle connected to 5v. I guess it worked for a while but fried over time. I flashed the vesc with new firmware but the setup input voltage still stays at 1.47v so it's probably cooked.
jozo
