FSESC 75100 Pro V2 W/ ALUMINUM
drstein99
Last seen: 12 months 1 day ago
Hello, I just received the Flipsky VESC, 75100 Pro v2 w/ aluminum case.  I load the VESC software tool on the PC,after correctly loading the usb port driver the software now recognizes the ESC.
The program reports firmware may be out of date.  So I go to the firmware page, just to check.  For reasons unknown, it is reporting that firmware for HW "75_300_R2" is loaded.
Fw: v6.02 (no_hw_limits), Hw: 75_300_R2
1E 00 3D 00 08 51 34 30 37 35 37 39
Paired: false, Status: STABLE
HW Type: VESC, Phase Filters: Yes
NRF Name: No, Pin: No
I am guessing this has been done in error, not sure how it happened, why or what the case is.  Can anyone advise please?  Do I just load the one from the 75_100_V2 directory on the github, no_hw_limit version and move on with this or should I stop ?
Brett.W
That is normal. It comes with that firmware.
CRTZ
Same here come with the 75_300_R2 Firmware i installed the 75_100_V2 it seems work but i noticed the motor internal resistance calculated from the esc is way off than the one calculated from a multimeter. Can i know if you used the firmware that come with the flipsky?
