2. Motor Setup Wizard
Submitted by frank on Tue, 2017-10-03 19:49
In this tutorial we will configure a genuine VESC® motor controller in combination with a BLDC motor.
We will run the motor in FOC mode and we will make use of Hall sensors.
Vesc-Tool_MSM_intro
Vesc-Tool_MSW_wiring
Connect your VESC® to your computer using a mini/micro USB cable.
Run the VESC®-Tool software.
Vesc-Tool_MSW_connect
Vesc-Tool_MSW_start
Vesc-Tool_MSW_default
VESC-Tool MSW_choose FOC
Now we get the following options:
FOC = Field-Oriented Control
Advanced control mode (sinusoidal, silent, more efficient,
better motor sensor operation).
May cause damage to 3rd party hardware!
BLDC = Trapezoidal Control
More simple control mode (block commutation), noisier, hall-sensor operation
less accurate at this stage. Safer for operation of 3rd party hardware.
DC = Only for DC motors. Use phase wire A and C only!
Vesc-Tool_FW_current limits warning
The following explanations will help you to configure your current limits correctly:
Motor Current Max: The maximum current your motor can handle continuously (Ampere). Please refer to the motor specifications of your motor. You may use lower values to de-power your setup.
Our motor can handle 50A, but we will only set it to 30A to get started. You can boost your settings once you feel comfortable. A safe approach towards higher values is highly recommended (e.g. start with 15A only).
Hint: This value can be greater than the Battery Current Max value, resulting in a higher motor power output at part throttle. At max throttle the Battery Current Max is the limiting value if set lower than Motor Current Max
Motor Current Max Brake: The maximum current output you allow your motor to produce when operated as a generator. Electric vehicles may use the motor as a brake, generating energy when slowing down the vehicle. The energy produced will be stored in the battery. In this tutorial we will set the value to -25A to get started. The value should not be higher than the max. continuous current specification of the motor.
Hint: Higher values will result in stronger brakes if the Battery Current Max Regen settings allows the storage of the current generated.
Battery Current Max: The maximum continuous current your battery is rated for. Please refer to your battery specifications for safe settings. LiPo-pack batteries are usually C-rated. A 5800mAh, 25C rated battery can handle 5.8A x 25=145A max. Manufacturers often overrate the batteries and cutting the value in half is recommend. We will use 72A max for safety reasons.
Hint: Since our Motor Current Max is set to 30A, we could use 30A for the battery as well.
Technically there is no reason to use a higher value than the Motor Current Max.
Battery Current Max Regen: The maximum current you allow the VESC to push towards your battery or battery management system (if incorporated in your system) when braking. This value should not exceed the maximum charge current rating of your battery or capability of your battery management system. Our battery is 5C rated for charging. We use a 5800mAh battery.
5.8A x 5 = 29A max. charge current.  Again: Better be pessimistic with those values! We will set it to -20A.
Hint: Since this value is lower than the Motor Current Max Brake (-25A), the firmware will limit the ampflow towards the Battery to -20A, regardless of the higher value we specified for Motor Current Max Brake (-25A). In consequence our maximum motor brake force is limited by the lower Battery Current Max Regen value.
Vesc-Tool_MSW_current limits set
Vesc-Tool_MSW_battery cutoff_warning
Now we will configure your battery cutoff voltage.
If you discharge your battery below a certain voltage, it will get damaged permanently. LiPo packs or Lithium ion Batteries usualy operate between 4.2V and 3.1V per cell. Do not allow your system to discharge them beyond 3.1V per cell! For this reason the VESC will measure your battery voltage and will start to softly cutoff the power at 3.4V per cell (Battery Votage Cutoff Start) and it will perform a hard cutoff at 3.1V per cell (Battery Votage Cutoff End).
You can also set custom values if your cells have different ratings.
Battery Voltage Cutoff End = number of cells in series x minimum cell voltage
VESC-Tool MSW_battery cutoff_set values
Next step is the choice of motor sensors
Sensors help the VESC to know the rotor position in refenrence to the copper coils. This way the motor can perform a relatively smooth startup from 0 RPM. If your motor features sensors you should make use of them. At higher RPM, the VESC will use back EMFs to calculate the rotor position. The RPM for switching to back EMF operation can be defined later.
No sensors: without motor sensors the motor needs to turn a bit, so the VESC can calculate the rotor position from the back EMF current flow that the magnets will induce into the copper coils when they rotate around the  the motor stator. Startup from 0 RPM is possible but a bit shaky.
Hall sensors: A transducer that varies its output voltage in response to a magnetic field. Usually a set of three sensors are acurately positioned inside or outside the motor to roughly determin the position of the rotor.
Commonly used, not very precise, good enough to guarnatee a smooth startup of a vehicle from standstill.
AS5047 Encoder: This is a chip sensing the magnetic field of a diametrally magnetized magnet, attached to the motor shaft. The precision is very high (14 bit) and allows very accurate determination of the rotor position.
ABI: Output signal of an incremental rotary encoder (mechanical, optical or magnetic).
Our motor has Hall sensors, so we will choose Hall sensor operation.
Vesc-Tool_MSW_select sensors
Next step is to measure your motor parameters
For the best possible result, do the detection without attached drive train, propellers etc.
Every single motor is unique and the VESC needs to know certain parameters to run the motor. The VESC needs to know the motor resistance, electrical inductance and flux linkage (λ). From these basic values other values can be calculated that are essential for the motor operation. So that‘s what we will do now.
Step 1:measure RL
The motor will make a loud humming noise
Step 2:measure λ
The motor will spin up. Make sure to disassemble propellers or lift up your vehicle from the ground or take any preparations necessary to allow your motor to spin up freely.
Step 3:Apply values
Vesc-Tool_MSW_motor parameter_01
Vesc-Tool_MSW_motor parameter_02
Vesc-Tool_MSW_motor parameter_03
Vesc-Tool_MSW_motor parameter_04
Vesc-Tool_MSW_motor parameter_05
Vesc-Tool_MSW_sensor calibration_01
Make sure that your motor can rotate freely, since the motor will start to turn slowly now.
Vesc-Tool_MSW_sensor calibration_02
Vesc-Tool_MSW_sensor calibration_03
Vesc-Tool_MSW_finish
Congratulations, you have finished the Motor Setup Wizard.
Please continue with the Input Setup Wizard.
Comments
This tutorial provides a clear, step-by-step approach to configuring a VESC® with a BLDC motor, but it feels very technical and dense for beginners. Just like coloring pages at ColorearW.net (PDF to print for free) simplify creativity, this guide could benefit from more visuals, summaries, or flow diagrams to make learning smoother.
jackryan2408's picture
Balancing university deadlines and technical subjects can be really stressful, which is why I rely on Rapid Assignment Help UK for reliable Help on Assignments. Their team of experts makes even the most complicated topics manageable. For engineering students like me, their Engineering Assignment Help UK is a lifesaver. They provide well-researched, plagiarism-free solutions for projects, case studies, and problem-solving assignments. The explanations are clear, and the work is always delivered on time, which has significantly reduced my academic stress and helped me improve my grades. Highly recommended for anyone struggling with coursework!
As a student, you always try hard to score good grades in academics. However, achieving excellence in study and academic tasks is not easy for everyone. The complex topic and academic demands make the writing process more difficult for students. For any type of difficulty in the study and academic project, you can get Assignment help online in Australia from experts. Professional experts are highly trained and experienced in tackling complex projects or topics. They provide conceptual detail on the topic in a simple and effective manner. Their support allows students to acquire a better understanding of the topic and learn ways to tackle questions or subject problems efficiently. It helps you to perform well in exams and academic tasks. Getting professional assistance in a writing task, you can save time and effort to focus on other things. It helps you enhance learning and secure good grades.
Epson is a leading name in printers, scanners, and imaging solutions. When you face issues like installation errors, poor print quality, or connectivity problems, how do you reach Epson support? This guide outlines the direct methods to contact Epson Customer Care — via phone, live chat, email, or social media — and offers tips to make the conversation efficient. Be prepared with your model and serial number, warranty status, and clear descriptions of the issue. Also learn when basic troubleshooting at home helps, and when it’s best to talk to a care representative to resolve your problem fast.
https://sites.google.com/view/epson-customer-service-/home
Basketball Stars Thank you for sharing this comprehensive VESC motor setup guide! I've been working with BLDC motors recently and this tutorial is incredibly helpful, especially the detailed current limit explanations. The emphasis on starting with conservative values and gradually increasing them is solid advice - I learned that lesson the hard way with my first build!
"Nice to be visiting your blog again, it has been months for me. Well this article that i’ve been waited for so long. I need this article to complete my assignment in the college, and it has same topic with your article. Thanks, i am for the first time here. I found this board and I in finding It truly helpful & it helped me out a lot. I hope to present something back and help others such as you helped me.먹튀
Do you need assistance managing your online classes? Reach out to takemyclassforme.us.com! We provide expert academic support in all subjects, including math, science, and business. Specifically, our qualified tutors handle your coursework, quizzes, exams, and assignments with assured outcomes. To help you achieve academic success, we provide 100% confidential services at competitive prices. No matter whether you are a busy professional or an overburdened student, we make studying stress-free through our 24/7 reliable guidance. Simply say, “Take My Class For Me”, and let our experienced tutors handle the rest.
This is a clear and practical guide on setting up the VESC® motor controller — great work, Frank! ⚙️ The step-by-step explanation makes it easier for enthusiasts and engineers to configure their BLDC motors efficiently. For students or professionals working on similar technical projects and needing help documenting their process, assignment writing services UK can be a huge time-saver, ensuring your reports and analyses are well-structured and polished.
Having trouble logging into Crypto.com? Discover solutions for common login issues like password errors, 2FA problems, and app glitches. Learn how to reset your credentials, update the app, or contact support. This quick guide helps you fix login problems and regain secure access to your Crypto.com account on both mobile and desktop platforms. Crypto.com login issues | Crypto.com login issue
When it comes to labor management solutions, Global 110 LLC is an example of the best  Workforce Management Software . We provide feature-rich, user-friendly, secure hosted solutions for contact centers of all sizes and are dedicated to quality. Our platform, intended to improve efficiency and streamline operations, combines technology with industry knowledge. Since we at Global 110 LLC are aware of the constantly changing needs of contemporary contact centers, our solutions are designed to accommodate new demands easily.
Take your coaching to the next level with Coach Campbell, Football Coaching Books—trusted by new and veteran coaches alike. Whether you're aiming to be a head coach or assistant, these books offer real insights, strategies, and motivation to help you succeed. Known as some of the Best Football Books  out there, they're packed with practical tools for building winning programs. Don't miss your chance to grow with Campbell Football—your go-to source for top football books and coaching success.
Midnight Cry Evangelistic Ministry , founded in 1977, is a Christ-centered Evangelistic Center Church with a mission to reach the lost, strengthen believers, and prepare hearts for the Lord's return. Through powerful preaching, dedicated Church Ministries, and a welcoming Church Hospitality Ministry, we create a place where faith grows and lives are transformed. Rooted in love, service, and truth, we invite you to join us in sharing the Gospel, building the body of Christ, and answering the Midnight Cry.
At 7Stami, we're dedicated to empowering women through wellness, support, and career development. Our Women's Wellness Center offers holistic health services tailored to women's unique needs, while our community health and wellness programs promote balance and connection. We provide guidance on careers for women, host rejuvenating wellness retreats for women, and create safe spaces where Women with Women can grow and thrive together. Whether you're seeking healing, purpose, or professional direction, our women's center for health and wellness is here to support every step of your journey. 7Stami is where women uplift women—mind, body, and spirit.
Thanks  for every other informative site. The place else may just I get that kind of information written in such an ideal means? I have a venture that I’m just now operating on, and I have been on the look out for such information. I also wanna talk about the best full spectrum cbd oil.
Wow, this really hits home and makes me reflect on my own experiences with such thoughtful insights. It's incredibly moving and thought-provoking. For more engaging experiences, check out Poki for a great selection of free online games.
This tutorial on configuring a VESC motor controller is incredibly detailed and helpful! I especially appreciate the clear explanations of the different control modes like FOC and BLDC, along with the guidance on setting current limits and battery cutoff voltages. The step-by-step instructions for measuring motor parameters are also really useful for getting the best performance. If you're looking for a quick and easy way to visualize your project, check out Free AI Image Generator By Nano Banana Pro. It's great for generating images based on text prompts.
sprunki mods's picture
What a great essay.
earn to die This article piqued my interest. It provides the reader with the most important key information and makes a strong argument. You can refer to
Slope Run to make your argument even stronger!
Deerfoot Casino is very approachable for Canadians who are new to online gambling. The interface is intuitive, and they provide clear instructions for each game. I quickly learned the basics of blackjack and roulette. For newcomers in Canada, Deerfoot Casino makes starting easy and enjoyable.
In this tech-driven world, taking online classes has become common these days. Many students who are struggling with understanding the subject and completing their course seek online class assistance. There are numerous services that offer online classes to help students. Choosing the right service is the biggest hassle for everyone. You can take my online class for any subject that you find hard to understand. Prefer a reliable service by checking the ranking and rating. Ensure they have a team of experts in all academic disciplines, and they possess higher qualifications and relevant experience. Choosing a reliable learning platform, you can access the best support in the educational process that ensures better comprehension of subjects and success in your studies. Check the pricing factor while seeking a professional online class and ensure affordability in learning.
Log in to your PayPal account to securely send and receive money, pay for purchases, and manage your financial transactions online. Access your balance, track payments, and update account settings with ease. Enjoy a fast, reliable, and safe platform trusted worldwide for convenient money management anytime, anywhere. Paypal Login | Paypal Login
The VESC Motor Setup Wizard is highly technical. It requires technical Precision in setting current/voltage limits and intense Focus on hardware specs. Successful configuration also demands parameter Agility for optimal performance. Hone these skills in the video game Slice Master.
I've always struggled with managing multiple deadlines, so I eventually turned to Assignment Helper UK just to survive the workload. I didn t expect it to make such a huge difference, but it honestly did. They helped me get my workload under control and, for the first time, actually understand what each assignment was asking for. Later, when my coursework started getting tougher, I tried SPSS Assignment Help, which helped me make sense of all those confusing statistical tests, outputs, and data interpretation steps, and that honestly became a complete lifesaver. Instead of feeling lost in criteria, units, and endless task requirements, I finally had someone guiding me through everything in a way that actually made sense. What I liked most was how patient and clear the explanations were they never made me feel silly for asking basic questions. Little by little, the stress dropped, and I started submitting work that I felt proud of. I could finally balance university, work, and my personal life without constantly feeling like I was drowning.
For many students, the school network is a fortress of restrictions. While teachers are focused on blocking games and social media, a simple, fun tool like a Soundboard often gets caught in the digital crossfire. Yet, a Soundboard can be an excellent, lighthearted tool for enhancing class presentations, adding humor to study group chats, or simply enjoying quick entertainment during downtime.
The key is finding a Soundboard Unblocked—one that is specifically engineered to bypass the common firewalls used in educational institutions. This guide provides the tech tips you need to identify a truly reliable platform, using SoundboardMax.com as the definitive example.
1. Understanding the "Unblocked" Challenge at School
Why do most soundboards fail at school? Network filters often block websites based on large file types, excessive bandwidth usage, or domain blacklisting. A truly reliable Unblocked Soundboard must counteract these measures by prioritizing specific architectural features:
  • Low Bandwidth Footprint: It must load quickly and efficiently without draining the network.
  • Simple Web-Based Design: Complex software or extensions are red flags for network security. A purely browser-based tool is essential.
  • A Clean Domain: The platform must be hosted on a clean, reputable domain that hasn't been flagged for previous rule violations.
2. The Must-Have Tech Criteria for a School-Friendly Soundboard Unblocked
When searching for a solution, apply these five technical filters to guarantee Seamless Access within a restricted network:
Tip 1: Seek 100% Browser-Based Functionality
A reliable Soundboard Unblocked should advertise zero downloads. Software installation is impossible on most school computers. The platform must work instantly just by opening the URL, functioning on any device—PC, Chromebook, tablet, or phone. SoundboardMax, for example, is entirely browser-based, making it perfectly suited for these environments.
Tip 2: Prioritize High-Quality, Curated Audio
Counterintuitively, quality helps with being unblocked. Platforms with random, low-quality uploads often contain huge, unoptimized files that trigger network alerts. Look for a Meme Soundboard that explicitly states its audio is vetted, trimmed, and crisp. This indicates efficient file management, leading to better Seamless Access.
Tip 3: Look for a Meme Soundboard Unblocked Commitment
The platform must explicitly state its core promise is to be "unblocked." This indicates the developers have spent time engineering the backend (like using different hosting or file delivery methods) to reliably bypass filters. SoundboardMax's core feature is its commitment to being the ultimate Soundboard Unblocked.
Tip 4: Simple, Intuitive Navigation
If the site is cluttered or requires complex navigation, it makes the platform feel clunky and potentially suspicious. A simple, well-categorized interface with a powerful search function (like the one found on SoundboardMax with categories like Sound Effects and Notification Soundboard) ensures you spend less time searching and more time using the sound—a key aspect of an efficient Unblocked Soundboard.
Tip 5: It Must Be 100% Free
Any requirement for payment or subscription immediately adds complexity (and scrutiny) to the platform. A service that is completely free removes a potential barrier to access and ensures maximum simplicity.
Conclusion: Your Reliable School Solution
For students seeking a fun, functional, and hassle-free audio tool, choosing a Soundboard Unblocked that meets all these criteria is vital. By prioritizing platforms that offer 100% browser-based access and a Meme Soundboard library with high-quality, efficient files, you maximize your chances of enjoying seamless, unrestricted audio entertainment even in the most protected network environments.
When choosing a modern yet reliable online gaming club, I usually look at how well design and performance work together. In Australia, platforms inspired by  Stellar Spins Casino often aim to combine a fresh visual style with stable technical foundations. Clear navigation, fast loading, and consistent gameplay show that the platform is thoughtfully built. These qualities are especially important for players across Australia.
Speed Stars's picture
When you play Speed Stars , you become a top speedrunner and fight in fast races to win difficult tracks. Do you think you're very good at time, speed, accuracy, and rhythm?
spanish dictionary
Speed Stars game
Access your crypto safely with Trust Wallet Login. Learn how to sign in, connect your wallet, and manage assets across blockchains. This guide covers secure login steps, common issues, recovery tips, and best practices to protect your keys while sending, receiving, staking, and swapping tokens using Trust Wallet on mobile and browser platforms with confidence and enhanced privacy controls today. Trust Wallet Login | Halo Wallet Extension
A detailed review of the Plinko slot game in Pakistan shows that stake users often appreciate how seamlessly Plinko integrates into a larger gaming environment. The game stands out due to its fast rounds and visual clarity, making it a refreshing option for Pakistani players already accustomed to polished platforms with high performance standards.
From my experience, consistency matters more than flashy promotions. ZeusWin Casino stood out to me after a few weeks of regular play, especially due to its fair gameplay and predictable payout system. For players based within England, this reliability is crucial, as regulations are strict and expectations are high. The platform feels well-established, with smooth navigation and a balanced selection of games that doesn’t overwhelm new users.
Coinbase login allows users to securely access their crypto account to buy, sell, trade, and manage digital assets. Sign in using email, password, or wallet connections, enable two factor authentication, and monitor balances, transactions, and portfolio performance across web and mobile platforms safely with reliable support and compliance standards worldwide. Coinbase Login | Coinbase Pro Login
Spicy Nashville-style chicken tenders sliders combos sides heat levels bold flavors crispy texture satisfying portions crowd-pleasing fast casual experience served fresh daily fans love it worldwide Dave's Hot Chicken Menu
I agree with the points made above. Just a small hardware tip for the community: when you're staring at data logs and fine-tuning motor parameters, eye strain can be a real issue if your screen isn't calibrated. If you need a pink background for display checks, a lightweight display tool is a solid option that loads immediately. It helps you spot any backlight issues or defects before they become a distraction during your build.
Reading thoughtful pieces about tech resistance reminds me how important it is to reduce visual noise when using devices. For quick screen checks or moments of digital rest, an [url=https://blackscreen.space]online black screen tool[/url]
Online dating has become a natural part of modern life, opening up new opportunities for people to meet and connect with russian women. It helps people find like-minded people, even if they lack the time or courage to take the first step in real life. Correspondence allows you to get to know someone better, their values, and their interests before meeting in person. This often leads to more meaningful and relaxed relationships.
