Flipsky FSESC 6.9 encoder does not work [SOLVED]
canoeman
Last seen: 5 months 4 days ago
The Flipsky FSESC 6.9 has filtering capacitors on the hall input lines. The circuit is not exactly like Vedder's original vesc 4, or Vedder's vesc 6. When you want to use an encoder (SPI or ABI), these capacitors will make it work poorly or not at all. Here is a picture of the specific ESC in question:
Here is a picture of the location of the capacitors that have to be removed when using an encoder:
Notes:
  1. NOT ALL flipsky fsesc products require capacitor removal in order to use an encoder.
  2. These capactors are surprisingly hard to remove, probably due to lack of any thermal relief and/or high melting point solder. It is easy to damage the traces/pads in the process. Be careful.
Other keywords/phrases so this post can be found by those in need:
AS5047, AMT, CUI, quadrature, flipsky encoder wont work, how to connect encoder to flipsky, encoder does not read, hall signal buffer, hall signal low pass filter, flipsky encoder problem
Jonasbuilds
Last seen: 11 months 21 hours ago
Hi, thanks for the information.
I’m currently trying to use a Flipsky 75200 V2 (Alu) with an AS5047P sensor.
I’m running into the problem that the VESC does not detect the AS5047P at all.
When I run the setup wizard, it always detects the motor as sensorless.
Do you think this is because the 75200 has the same capacitors?
Or do these capacitors just disrupt the signal but don’t actually block the connection, meaning my problem originates from something else?
