CAN sends error frame
dgarciasoto
I'm communicating with the VESCs using CAN, sending RPM commands. I send them at 100hz
If I send very slow speeds or zero the VESC doesn't have enough power to move that slow and sends error frames on the CAN bus.
The microcontroller I'm using enters bus-off mode because of that and disables CAN communication until I reset it.
How can I make the VESC not send error frames in this situation?
fingerprintdax
Any resolution on this? im getting Error messages from VESC as well.
fingerprintdax
any resolution on this? i have same issue
