VECT Tool freezes after uploading lisp script
realphanta
I uploaded a script to a MKS 75100 that turned out to be a permanent loop over the print method. Now VESC Tool completely freezes under Windows 10 after connecting to the controller via USB. It manages to read the hardware version, which is shown in the bottom bar, but that's it. I tried VESC express, but it is unable to establish a CAN connection too.
The auto-run checkbox was checked when uploading the script, so restarting the controller leads to the same state.
Is there any way that I'm missing, to get the controller to communicate again, without SWD reprogramming/unbricking?
realphanta
So my STLink programmer arrived. It was a thing of 5 minutes. But I wish there was an easier way, like shorting two contacts and so it doesn't start lisp or something,
realphanta
I ran into the Problem three Times already. Is there not any way to stop a script from running on startup?
I tried auto-run unchecked, but it still starts the script on every startup once activated manually.
