Cannot connect win10 tried everything I have read
meziked
Hello all,
I purchased a FT85BD 75V100Ax2 from amazon and have spent around 6 hours now trying to get it to connect. I am using the cable provided and have tried multiple known working data cables. I have downloaded the virtual driver from ST link and the software recognizes the device and gives me the option to connect to it. When I try to connect, its says its connected for a few seconds then gives me the error it cannot read the firmware file and asks if I am on the correct com port (I am). I have also checked baud settings for the port. and they match. I thought maybe a firmware issue, so I have tried every version of  the VESC tool with the same results.Pretty bumbed right now as I do not want to return this as I need it, like now. I've read things about certain versions being shipped with no firmware or bootloader, maybe Im one of the lucky winners? If so, what then? I have an ST-Link and have done little things like flash hoverboard controllers, but man.. I'd sure like to avoid soldering on my new 150 dollar esc. I bought this part to avoid most of this. I feel like I'm just missing an important step as the tool sees the device on the port but wont connect. Shot in the dark... any help before I return this? (just an edit to add: I'm powering it with a 10S lipo at around 36 volts.)
electricfox
electricfox's picture
Last seen: 1 hour 24 min ago
FT models from Flipsky are "NON-VESC".
meziked
Yeah, I learned that the hard way. I wish the link for software was to the correct application in the instruction sheet provided.
I've connected and started tuning using the ESC tool. Now if anyone knows how to tune a 15 pole 36v 10A hub motor, please help me out. Larger diameter slower motors so the defaults do not work. The canbus test runs it perfect towards the end of the test, but then the application crashed and I lose that setting. (See what it can do....denied!!..heh).
Cassxoxo5912
Last seen: 2 weeks 18 hours ago
were you ever able to sort this out? I had the flipsy ft85bd w vx4 controller when it first came out and after couple weeks was finally able to get it going right where i just do street tune on the controller whenever wanted to which was awsome! Long story short i had ended my relationship and basically she kept my main esk8t shit etc etc cant get back blah blah so...i got another one this time no vx remote. i got the generic flipsky old remote w no display. anyways now though i cant even get damn thing to connect at all like the problem you had or have w the shitasking if correct com port etc etc. So please let me know if you did get it fixed? lastly can the mobile app connect if i use a non flipsky ble chip that i wire to the FT85BD?!
Cassandra
Cassxoxo5912
oh btw we used her info for this account. im not her Im him...Baker or can hit me on gram at....    sgtbm3   PLZ  ADVISE THANKS BOARDBROS LOL
Cassandra
shabo
shabo's picture
i am having similar problem i have the FT85BD and are unablr to coonect or use the controller need help. im on a windows 11 laptop. which the correct software i should be using?
shabo
Drummerv4141
Drummerv4141's picture
Im using a ft85bd dual controller have everything hooked up and program but I cant figure out how to make the slave motor to run when I apply the throttle. Master motor works just fine. Please anyone help me to troubleshoot this issue...
Charlie
