Dev Tools (Scripting)
curt
Hi all,
I am trying to read a voltage [0-3,3V] from ADC1(SCK_ADC_EXT) but I always get an error: ReferenceError: val is not defined
import QtQuick 2.7
import QtQuick.Controls 2.0
import QtQuick.Layouts 1.3
import QtQuick.Controls.Material 2.2
import Vedder.vesc.utility 1.0
import Vedder.vesc.commands 1.0
import Vedder.vesc.configparams 1.0
Item {
    anchors.fill: parent
    anchors.margins: 5
    property Commands mCommands: VescIf.commands()
    property ConfigParams mMcConf: VescIf.mcConfig()
    ColumnLayout {
        RowLayout {
            Layout.fillHeight: true
            Layout.fillWidth: true
            CustomGauge {
                Layout.preferredWidth: gaugeColumn.width * 0.45
                Layout.preferredHeight: gaugeColumn.height * 0.45
                maximumValue: 10
                minimumValue: 0
                tickmarkScale: 1
                labelStep: 1
                //value: 0
                unitText: "V"
                typeText: "ADC 1"
    Timer {
        running: true
        repeat: true
        interval: 20
        onTriggered: {
            VescIf.canTmpOverride(false, 113)
            mCommands.getDecodedAdc()
            mCommands.getValues()
            mCommands.ioBoardGetAll(113)
            VescIf.canTmpOverrideEnd()
    Connections {
        target: mCommands
        onValuesReceived: {
            console.log(values.vesc_id)
            console.log(values.rpm)
            console.log(val.adc_1_4[5])
        onIoBoardValRx: {
            console.log("onIoBoardValRx")
            console.log(val.id)
            console.log(val.adc_1_4[0])
            // console.log(val.adc_5_8[0])
Did some of you already connect an external analog signal to the VESC reading the value? I want to use the value to optimize the control of two motors by a calculation using that measured value from ADC1.
Thanks for ideas
nico01
Last seen: 9 months 3 hours ago
 Hello Curt,
The code below works on 6.02.
import QtQuick 2.7
import Vedder.vesc.vescinterface 1.0
import "qrc:/mobile"
Item {
  property real vAdc1     : 0.0
  property real valueAdc1 : 0.5
  property real vAdc2     : 0.0
  property real valueAdc2 : 0.5
  Timer {
    interval: 50
    running: true
    repeat: true
    onTriggered: {
      if (VescIf.isPortConnected() && visible) {
        mCommands.getDecodedAdc() }
  Connections {
    target: mCommands
    function onDecodedAdcReceived(value, voltage, value2, voltage2) {
      valueAdc1 = value
      vAdc1 = voltage
      valueAdc2 = value2
      vAdc2 = voltage2
  ColumnLayout {
    RowLayout {                     // ligne 1
      CustomGauge {                 // ADC 1 gauge
        Layout.preferredWidth: gaugeColumn.width * 0.3
        Layout.preferredHeight: gaugeColumn.height * 0.3
        maximumValue: 5
        minimumValue: 0
        tickmarkScale: 1
        tickmarkSuffix: ""
        labelStep: 1
        value: vAdc1
        precision: 2
        unitText: "V"
        typeText: "ADC 1"
      CustomGauge {                 // ADC 2 gauge
        maximumValue: 5
        minimumValue: 0
        tickmarkScale: 1
        tickmarkSuffix: ""
        labelStep: 1
        value: vAdc2//1.10
        precision: 2
        unitText: "V"
        typeText: "ADC 2"
Tschüss
