config wanted, for 75100 with ebike geared hub motor
tom355
Hi everyone. I am not able to create a smooth running setup Gmac/flipsky 75100 with FOC and hall sensors.
Runs perfect when wheels are in the air. runs horrbible under load when i am sitting on it.
Runs smooth when i accelerate VERY careful and gently, when i pull the throttle harder it`s
stuttering and making noises.
Playing with the values now for weeks, that`s why i am looking for a config file now
Do you have a good running setup with the 75100 and a geared ebike hub motor
(e. g. Gmac). ? Would you send it to me?
Pleas contact me!
Oded Mazor
Can you share a screenshot of the current (motor, battery, peak...) Settings?
What battery are you using?
jbturbofly
Last seen: 1 year 4 weeks ago
I have the same problem.. while the motor works on hall sensors everything is more or less normal, but when switching to sensorless it stutters and the error abs_over_current
observer_gain tried different from 0.75 to 100
JanneHooo
Hello. I have similar symptoms with my UGV. When starting from zero it has huge problems to run but after getting on some speed (around 5km/h) it runs well. Motors have HALL sensors attached but i am not sure if they are configured properly in vesc tool. Hallsensors have text ZZ110HALL_v1.0
