ADC Signal not recognized
reichs
after some years I want to continue my project with an motor and Flipsky FSESC6.7 again.
With the wizard, I could configure the motor, however I have some issues with the signal. I wanted to use a simple potentiometer for the beginning which I connected to the 3 wires from the FSESC.
I get 5V from the FSESC and on the output, i get a signal between 0-5V, which I put back to the FSESC signal line. (white cable). However, if I go to the VESC tool --> Welcome&Wizards --> Setup input, the ADC voltage stays at ~1.5V and does not change.
U think when I tried this the last time some years ago, it worked without issues - later I changed it to PPM-input, bit for now I would like to start again with the simple potentiometer.
Does anyone know, what could be my mistake? Maybe it is quite simple...
Best regards
Stefan
Foujiwara
Flipsky and many controller are not 5v tolerant on ADC, so if you put 5V on it you rislk to just kill the ADC I/O
If you Select ADC and clic on App RT data button and it's not working it's just you kill the ADC input
ADC are 3.3v, upper than than you need to use bridge divider or use 3v to supply your throttle
So if you kill the ADC you just gave to check the serie resistor of ADC in case or change the MCU (STM32), or juste buy another controller and take care to not make mistake that time
