Overvoltage Error during setup
arranto12
OK. I've perhaps been abit of a tit.
I have purchased a flipsky Mini FSESC4.20. While I was waiting a week for it to arrive I noticed the maximum voltage of this VESC is 60v... so I calculated that at maximum charge I can build a 14s battery which gives 58v.
I received the vesc today and plugged everything together and tried an auto detection or whatever its called... and I get a detection failed error on the screen after 5-10 seconds of nothing happening. So I went online and found that if I type 'fault' in the vesc tool terminal I can get a fault code to show... and its showing "FAULT_CODE_OVER_VOLTAGE".
Is there any way of getting this to work without having to dissect the neatly wrapped battery... ripping the 14s bms out and forking out on a 13s battery to lower the voltage?
Now like a dumbass I ignored the quite clearly labelled flipsky mini FSESC4.20 labelling which says "3s - 13s LIPO' as I calculated that a 14s battery will never exceed 60v.
Any thoughts and suggestions?
You live. You learn. Ooops.
Thanks,
Arran.
12S max! You need 8V headroom for spikes! The FW and setting protects the unit from blowing up. 52V fully charged batteries is the very max. 51V is better.
you could use a high power step down converter or just 12s battery,
75v vesc
https://www.banggood.com/Flipsky-75100-FOC-75V-100A-Single-ESC-Based-on-...
Juan Parra
Hello, I have tried to configure the FSESC 75200 with a 20S battery (with VESC Tool software) but when I try to setuo the motor, it gives an overvoltage fault warning. I check the voltage range, ita beetwen 4S-20S, so im ok
I would appreciate if anyone have idea how to fix the proble, thanks a lot
JAP
electricfox
electricfox's picture
Online
Last seen: 13 min 27 sec ago
Over voltage fault might happen because you dont use a battery. If you use a power supply, it  can not take reverse current. Just use a battery then. Also ist could be of wrong firmware. Check your max Input voltage value. Some flipsky controllers need no_hw_limits firmware.
