IOS - VESCTOOL Run successfully ?
Bear Chris
Hello everyone, and a wonderful and happy VESC year! ;)
I’m using the version of VESC Tool I downloaded from the Apple Store, and I’m currently setting up my first board. Do you know if the iOS version is as stable as the Android version ? I’d like to know if it’s possible to use VESC Tool on my phone (iPhone) to configure my board and ride..., but is it also possible to use my Linux setup and the application to work on the same board without causing issues with my VESC configuration ?
electricfox
electricfox's picture
Last seen: 3 hours 26 min ago
Yes you can use both. I recommend doing the first setup on a PC to get a better understanding of it.
Bear Chris
Okay thank you @electricfox
Bear
