VESC 6.05/STR500 ADC1 dead
amblerev
Last seen: 1 year 12 months ago
I am doing a vehicle install. I bench tested the system before install, so ADC1 was working with the analog throttle at one point.. But after install ADC1 does not read any input, it stays reading ~.47v. regardless of the input voltage I switched the throttle wipe to ADC2 and the wipe did the full 0-3.3v range, so do not believe this is a throttle or wiring issue. Has anyone else experienced this issue, and were you able to wake up the ADC input. up? Assuming my ADC1 is non-recoverable, is there a way to use an analog throttle on a different input?
electricfox
electricfox's picture
Last seen: 1 hour 4 min ago
If your wiring is correct and you still get that problem, get in touch with Trampaboards.
