Dead zone after 50% increase
simDen
Last seen: 1 year 5 days ago
Hello everyone, please help me figure out the dead zone on the controller. The problem is that when the stick deviates from the center by more than 50%, the speed does not increase, that is, 0-50% of the active zone scale, 51-100% is inactive (I control ground equipment from the remote control, the values ​​​​on the remote control change 0-100% of the indicator, in the VESC program in the PPM display section it is the same for everyone 0-100%. But in life it seems that the speed increases by 50% and does not increase further, help with advice on where to look
Motor type: BLDC/FOC; Sensortype: Hall Sensor; Controller: tx12 (ppm signal)
electricfox
electricfox's picture
Last seen: 4 hours 53 min ago
VESC in Current control is not behaving as a RC ESC (electronic SPEED CONTROLLER) where you control your speed. If you want speed control you have to change it in App Configuration to Duty Cycle Control.
