Flipsky can't connect to vesc tool
vescbeginer
I have weird problem. I plugged flipsky to PC but vesc tool said
"Could not auto connect. Make sure that the USB cable is plugged in and that the VESC is powered".
I tried on different USB cables and diffrent USB ports but result is always the same. I used auto connect and reconect last conection and nothing.
Earlier everything works fine (I use the same PC, the same vesc tool, the same windows etc.) but today always show up this error.
Flipsky 75100 works fine with the motor but can not connect to vesc tool.
vescbeginer
Problem SOLVED but I don't know why it is happening.
Before plugged USB to PC I have to turn OFF controller and then turn ON and then plugged to PC and it works.
But when I plugged USB after riding bike then apear "Could not auto connect. ............ ". I don't know why but earlier it works in this case too.
ministeve2003
In case anyone else has a usb not connecting issue...I fixed mine by running the Impulse_rc_Driver_fixer that Ive used for years with drones and betaflight... once it says fixing you can close the app before its even done...
Hope this is helpful to someone...
Steven Kight
wimleo
Will give it a try, thanks.
Bbonsack
I just ran into this exact issue so I tried a different flipsky controller and it connected just fine. I don't know if there's an issue with the FT85BD but when I connected a FSESC 75100 I had no issues with connecting to VESC Windows tool. Anyone know how I can fix this
Bonsack
