In this tutorial we will configure a genuine VESC® motor controller in combination with a BLDC motor.
We will run the motor in FOC mode and we will make use of Hall sensors.
Connect your VESC® to your computer using a mini/micro USB cable.
Run the VESC®-Tool software.
Now we get the following options:
FOC = Field-Oriented Control
Advanced control mode (sinusoidal, silent, more efficient,
better motor sensor operation).
May cause damage to 3rd party hardware!
BLDC = Trapezoidal Control
More simple control mode (block commutation), noisier, hall-sensor operation
less accurate at this stage. Safer for operation of 3rd party hardware.
DC = Only for DC motors. Use phase wire A and C only!
The following explanations will help you to configure your current limits correctly:
Motor Current Max: The maximum current your motor can handle continuously (Ampere). Please refer to the motor specifications of your motor. You may use lower values to de-power your setup.
Our motor can handle 50A, but we will only set it to 30A to get started. You can boost your settings once you feel comfortable. A safe approach towards higher values is highly recommended (e.g. start with 15A only).
Hint: This value can be greater than the Battery Current Max value, resulting in a higher motor power output at part throttle. At max throttle the Battery Current Max is the limiting value if set lower than Motor Current Max.
Motor Current Max Brake: The maximum current output you allow your motor to produce when operated as a generator. Electric vehicles may use the motor as a brake, generating energy when slowing down the vehicle. The energy produced will be stored in the battery. In this tutorial we will set the value to -25A to get started. The value should not be higher than the max. continuous current specification of the motor.
Hint: Higher values will result in stronger brakes if the Battery Current Max Regen settings allows the storage of the current generated.
Battery Current Max: The maximum continuous current your battery is rated for. Please refer to your battery specifications for safe settings. LiPo-pack batteries are usually C-rated. A 5800mAh, 25C rated battery can handle 5.8A x 25=145A max. Manufacturers often overrate the batteries and cutting the value in half is recommend. We will use 72A max for safety reasons.
Hint: Since our Motor Current Max is set to 30A, we could use 30A for the battery as well.
Technically there is no reason to use a higher value than the Motor Current Max.
Battery Current Max Regen: The maximum current you allow the VESC to push towards your battery or battery management system (if incorporated in your system) when braking. This value should not exceed the maximum charge current rating of your battery or capability of your battery management system. Our battery is 5C rated for charging. We use a 5800mAh battery.
5.8A x 5 = 29A max. charge current. Again: Better be pessimistic with those values! We will set it to -20A.
Hint: Since this value is lower than the Motor Current Max Brake (-25A), the firmware will limit the ampflow towards the Battery to -20A, regardless of the higher value we specified for Motor Current Max Brake (-25A). In consequence our maximum motor brake force is limited by the lower Battery Current Max Regen value.
Now we will configure your battery cutoff voltage.
If you discharge your battery below a certain voltage, it will get damaged permanently. LiPo packs or Lithium ion Batteries usualy operate between 4.2V and 3.1V per cell. Do not allow your system to discharge them beyond 3.1V per cell! For this reason the VESC will measure your battery voltage and will start to softly cutoff the power at 3.4V per cell (Battery Votage Cutoff Start) and it will perform a hard cutoff at 3.1V per cell (Battery Votage Cutoff End).
You can also set custom values if your cells have different ratings.
Battery Voltage Cutoff End = number of cells in series x minimum cell voltage
Next step is the choice of motor sensors
Sensors help the VESC to know the rotor position in refenrence to the copper coils. This way the motor can perform a relatively smooth startup from 0 RPM. If your motor features sensors you should make use of them. At higher RPM, the VESC will use back EMFs to calculate the rotor position. The RPM for switching to back EMF operation can be defined later.
No sensors: without motor sensors the motor needs to turn a bit, so the VESC can calculate the rotor position from the back EMF current flow that the magnets will induce into the copper coils when they rotate around the the motor stator. Startup from 0 RPM is possible but a bit shaky.
Hall sensors: A transducer that varies its output voltage in response to a magnetic field. Usually a set of three sensors are acurately positioned inside or outside the motor to roughly determin the position of the rotor.
Commonly used, not very precise, good enough to guarnatee a smooth startup of a vehicle from standstill.
AS5047 Encoder: This is a chip sensing the magnetic field of a diametrally magnetized magnet, attached to the motor shaft. The precision is very high (14 bit) and allows very accurate determination of the rotor position.
ABI: Output signal of an incremental rotary encoder (mechanical, optical or magnetic).
Our motor has Hall sensors, so we will choose Hall sensor operation.
Next step is to measure your motor parameters
For the best possible result, do the detection without attached drive train, propellers etc.
Every single motor is unique and the VESC needs to know certain parameters to run the motor. The VESC needs to know the motor resistance, electrical inductance and flux linkage (λ). From these basic values other values can be calculated that are essential for the motor operation. So that‘s what we will do now.
Step 1:measure RL
The motor will make a loud humming noise
Step 2:measure λ
The motor will spin up. Make sure to disassemble propellers or lift up your vehicle from the ground or take any preparations necessary to allow your motor to spin up freely.
Step 3:Apply values
Make sure that your motor can rotate freely, since the motor will start to turn slowly now.
Congratulations, you have finished the Motor Setup Wizard.
Please continue with the Input Setup Wizard.
Comments
A monkeytype is an assessment
A monkeytype is an assessment or exercise designed to measure a person's typing speed, accuracy, and overall proficiency in using a keyboard to type written content. The goal is to evaluate how fast and accurately an individual can type a given set of words, sentences, or paragraphs within a specified time limit.
AI-powered writing assistance
If you're interested in AI-powered writing assistance, you should definitely check out EssayWriters AI. I stumbled upon a review https://essay-reviews.com/essaywriters-ai-review of this platform that provides valuable insights into how it works and its effectiveness. With advancements in technology shaping the future of education, platforms like EssayWriters AI offer a glimpse into what's possible.
What is the monkey type?
Monkey type is a free online typing practice website that offers a variety of typing tests and games to help improve your typing speed and accuracy. The website offers various typing exercises, including word, sentence, and paragraph typing tests, timed typing races, and typing games.
One of the features of Monkey type is that it provides real-time feedback on your typing performance, including your words per minute (WPM) typing speed and accuracy. It also provides detailed statistics on your typing performance, such as your error rate and typing speed over time, which can help you track your progress and identify areas for improvement.
Overall, Monkey type is an excellent resource for anyone looking to improve their typing skills, whether for personal or professional reasons. With various exercises and games to choose from, you can easily find typing practice that suits your needs and interests.
I'm sure the information here
I'm sure the information here is very useful, sometimes if you feel bored, you can try playing games, games like football legends will allow you to have fun and have a good time, such games are offered both unlimited and free.
RecCloud
RecCloud offers seamless cloud-based solutions for your business needs. Streamline data management, enhance collaboration, and boost productivity with our innovative platform. Discover the power of RecCloud today.
I never imagined being able
I never imagined being able to afford a home on my budget, but ModularList's modular homes under 40k changed that. The quality and design of these homes are remarkable for the price. It's incredible to see such value being offered, making homeownership accessible to more people. My experience with ModularList has been nothing short of amazing, from browsing to moving in.
subhanakhtar
Join millions of players worldwide in the daily quest to crack the Wordle puzzle. Wordle nyt
subhanakhtar
Wordle is a delightful way to sharpen your vocabulary while having fun. Wordle nyt
essayhub
As a student tasked with choosing a research paper topic, I often found myself overwhelmed by the sheer number of options. EssayHub's comprehensive list of research paper topics https://essayhub.com/blog/research-paper-topics came to my rescue, offering a diverse range of intriguing ideas across various disciplines. Whether I was interested in science, history, literature, or social issues, EssayHub had a topic that piqued my curiosity. The article provided valuable insights and inspiration, making the daunting task of topic selection much more manageable. Thanks to site, I found the perfect research paper topic that aligned with my interests and academic goals.
MetaMask Extension
Securely manage all your digital assets with the Metamask Extension. Keep your cryptocurrencies safe and easily accessible with this powerful browser extension.
Metamask Extension | Metamask Extension
Metamask Login : The Ultimate Crypto Wallet for DeFi, Web3 Apps,
Metamask Login : Logging into your Metamask account is a breeze, giving you instant access to your cryptocurrency wallet and decentralized applications. To begin, simply open your browser and click on the Metamask extension icon. Enter your unique password to securely unlock your account and start exploring the world of digital assets at your fingertips. Metamask Login
Once logged in, you can seamlessly view your token balances, send and receive funds, and interact with various decentralized platforms. Metamask Login ensures a user-friendly experience by providing a clean interface designed for both beginners and experienced crypto enthusiasts alike.
Metamask Login
Heardle celebrates the power
Heardle celebrates the power of music to evoke emotions and memories, creating a deeply engaging experience.
MetaMask Extension
Metamask Chrome - The ultimate browser extension for secure and convenient cryptocurrency transactions. Say goodbye to cumbersome wallets and hello to effortless managing of your digital assets. Download now! Metamask Chrome | Metamask Chrome
Great
I often learn many new techniques and strategies from other players in 1v1 lol, this helps me develop my skills quickly and create dramatic matches. This makes the game more interesting and always new every time you participate.
Guarda Wallet Extension
Guarda Wallet Extension is a game-changer in the world of cryptocurrency storage. This innovative extension offers users a secure and convenient way to manage their digital assets directly from their web browser. With Guarda Wallet Extension, you can easily access your cryptocurrencies without compromising on security. One of the key features of Guarda Wallet Extension is its user-friendly interface, making it easy for both beginners and experienced users to navigate. The extension supports a wide range of cryptocurrencies, allowing you to store all your digital assets in one place.
Venom Wallet Extension
Introducing the Venom Extension , a secure and user-friendly tool for managing your cryptocurrency assets with ease. This extension offers a seamless way to store, send, and receive various digital currencies all in one place.With Venom Wallet Extension, you can rest assured that your funds are protected through advanced security features like encryption and multi-factor authentication. Say goodbye to worrying about the safety of your crypto investments.
MetaMask Extension
Download the Metamask Wallet Extension for secure and convenient cryptocurrency management. Protect your assets and access them with ease using our innovative browser extension. MetaMask Wallet Extension | MetaMask Wallet Extension
