VESC 75/300 + Scorpion 7050 300kv for Combat Robotics Weapon
DabbingSnail
So basically I want to use the VESC 75/300 with a Scorpion 7050 330kv Sensorless Motor to spin a Flywheel of 13-14kg using a Pulley and belt system using 12S LiPo 6800mah
The Motor will spin only in one Direction but i will also like to add the function to switch direction of the Motor in the event that the Bot is inverted
I want help setting it up to be efficient without any twitching and the VESC to not reset during a match.
If anyone can guide me to the correct resource will be really helpful
electricfox
electricfox's picture
Last seen: 17 hours 42 min ago
Great project! There is no correct resource for it. You will have to find out and learn on your own reading in this forum, other forums, watching YouTube tutorials etc. If you don't want to spend time on that I might help you with your project, see my signature.
