Linux QT ERROR HOW TO FIX
Veerapandiyan
I am working vesc project. I changed the motor code then update vesc tool code and build is completed. Then opening qt.qpa "xcb" error is coming how to fix. I attached error screenshot below:
nambi@nambi:~/Downloads$ ./vesc_tool_6.05
qt.qpa.plugin: Could not find the Qt platform plugin "xcb" in ""
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Aborted (core dumped)
Regards,
Veerapandiyan V.
Veerapandiyan
Error solved. Remove all qt files then reinstall the commend working fine.
Regards,
Veerapandiyan.
Veerapandiyan V.
