Change sensor voltage on latest VESC 75/300 MK IV
R04
Hello folks,
First off, fan of the controllers and software .
Second, I received a newer MK IV and went to change the encoder sensor voltage to 3.3v and noticed the internal switch is gone.
Is there a recommended way to change the port over to 3.3v?
A schematic for the latest version would be a help as well.
The pcb shows "High Power Edition v3.4 AD".
Thanks for the info,
R04
R04
This might be an answer https://vesc-project.com/node/4331
I'll test and report back
The MK IV version has an automatic sensor voltage switch. It can also be manipulated via software.
