Kill switch only stopping one motor
bmblank
I'm using a flipsky dual 4.20 to drive 2 flipsky 6354 motors.
I'm new to brushless control, but I think I've got the settings mostly how I want them.  One thing that intrigued me was the killswitch option.
When I activate the killswitch (whichever option I choose; I can manage with any of them) it only kills one motor (local to the killswitch).
Is there a way to communicate that killswitch to both sides via CAN?  It seems like it should kill everything, but it does not.
I'm using ADC1 throttle with reverse button.  Am I religated to switching both sides of the ESC thru ADC2?  AFAIK (but I'm probably wrong) there is only one PPM
Thanks for the help.
electricfox
electricfox's picture
Last seen: 1 hour 37 min ago
For every VESC you need a separate Killswitch. You set up the master VESC with your ADC Inputs, the slave VESC should not be used/changed, except from killswitch in your case. When doing the "Setup Input" you should select the correct VESC as Master.
