Roll-to-start VESC
dsuresh
Roll-to-start VESC
It is mentioned in the page :1x VESC 6 MkV (trampaboards.com)
that it is possible to have Roll to start. how is that possible?
dsuresh
I tried wiring it up based on a momentary switch with the terminals conected to the pins. but it doesnt seem to start on rolling the motor.
Dave
robertkovax
Last seen: 1 month 11 hours ago
I'm having the same issue. Is the "roll to start" function supposed to detect the IMU acceleration? In this case the IMU should be calibrated in a certain way?
The MKV version switches on by default if you turn the motor fast enough. It needs to generate some voltage to activate the switching.
robertkovax
Thanks @frank, but I'm using the vesc on my ebike, where the motor is not engaged when i push the bike... That is why i'd like to use the IMU for start. Is there a possibility for that?
