Get values from slave VESC
Snabelost
I'm working on my dual electric motor boat and pretty much everything works except for one thing. How do i get values from the slave VESC?
I have an Arduino that talks UART to the master VESC and then the second is connected using the CAN-bus. I can control both motors perfectly using the following code:
UART.setDuty(LeftMotorDuty, LEFT_BLDC);
UART.setDuty(RigthMotorDuty);
I can also get values (like rpm, amps and so on) from the master VESC. The question is how to get values also from the second VESC?
/Magnus
Snabelost
Sorry, it was simple when i used the correct library. I was not using SolifGeeks, but now I have switched to that and now it works.
