VESC fault over voltage
ilhamdestyo
ilhamdestyo's picture
I have some problem about fault indication of my VESC project, so I'm trying to use the 75 300 firmware for a motor control project on an ev. but every time I use the throttle at maximum throttle a FAULT_CODE_OVER_VOLTAGE fault occurs. so how to fix that?
electricfox
electricfox's picture
Last seen: 2 hours 5 min ago
Check your Voltage in Motor Settings->General->Advanced->Maximum Input Voltage. Not sure if the Faultcode was implemented yet for this: App Settings->ADC->Mapping->ADC1 ABS Max Voltage.
