Wireless Touch Displays - large and small
10 posts / 0 new
Have been working on these displays for a while now and got some good progress.
Features:
1. Full color, high quality capacitive touch displays (different sized available - from 2 to 7 inches)
2. Wireless (BLE) communication (just need 5v power), VESC protocol supported
3. WiFi for seamless over-the-air updates
4. On board SD card slot for logging, etc.
5. Dashboard function (implemented)
6. Full motor detection function, quick settings, etc. support (in progress)
This is what it looks like at the moment. More details and updates to come.
Svein Utne
Very nice Vadicus, this might be what I need in my sailboat. It is an Ericson 41, so I should not reduce the voltage too much, to be able to get full power out of the motor I got. 100V 100A. Some say I can push it to 110v and 100+ A with no problem, as long as I can cool it. In normal operation the battery capacity is the limiting factor so I will go at 60V 60A most of the time, but in emergency I might need more power to get the boat up against the wind or current. Then 10 till 15 KW might be on the low side. So I am interested in some controller that can handle that power.
What is your time for delivery, and price?
Is it possible to buy it as kit and make it my self?
Sorry, I wrote a reply but didn't click the save button.
It's always a good idea to have a headroom in terms of power, and, especially, for emergencies. Good reliable systems are 'overbuilt' for reliability and that 1% of time when you'll appreciate you have an extra oomph. If you build a system for 10kw and run it at 10kw, it will be under stress most of the time. If you build a system that rated for 25kw, it will be much happier running at 50-75% of its capacity.
Regarding the delivery, ~ 2-3 weeks, the price is available here: http://powervelocity.com/home/60-24f-nextgen-pv-controller.html
Not sure about the last question. The controller is available for sale and can be configured from the phone app. The touch screen will be available very soon.
Svein Utne
Thank you for your link. I looked at this, and it might be what I need.
15KW 120V SINEWAVE/SILENT CONTROLLER - ANDROID-IOS-BLUETOOTH DASH & PROGRAMMING
$399.00
I will try to find more info on this.
Regards
Svein Utne
Svein Utne
I would like to order one.
$399.00
Svein Utne
Gjortlerveien 14
7021 Trondheim Norway
Result:
There are not enough products in stock
How long time will it take to get one in stock?
you were looking at a non-vesc controller.
This is the correct link: http://powervelocity.com/home/60-24f-nextgen-pv-controller.html
Svein Utne
Sorry, but I your controller is overkill for my 10KW motor. I found this Tronic 250R that can handle more than100V and 250 amp at $400. It might be just what I need.
Regards
Svein
Yep, no worries.
olivier-motor-co
olivier-motor-co's picture
Last seen: 1 month 18 hours ago
nice display can we change the 0 to 100 speed for rpm ?
and have batterie soc on the right side of the display ?
do you sale it ?
Best regarde M.olivier
keep tune olivier motor co
The display scales are self adjusting (based on the highest and lowest values observed). Yes, of course, the battery SoC is one if the main metrics on the main screen. It should be available for sale in February.
