DRV8301 always fault
NIKTEN96
i made a custom PCB following the VESC 6.4 schematic. But when i have to setup my motor (Flipsky 6354) it makes a little sound for 1/2 of a second and after returns the error:
Fault            : FAULT_CODE_DRV
Motor            : 1
Current          : -0.0
Current filtered : -0.0
Voltage          : 41.62
Duty             : -0.000
RPM              : 0.3
Tacho            : 2
Cycles running   : 0
TIM duty         : -1
TIM val samp     : 3360
TIM current samp : 3360
TIM top          : 6720
Comm step        : 0
Temperature      : 21.35
DRV8301_FAULTS   : | FETLC_OC | FETHC_OC | FETLB_OC | FETHB_OC | FETLA_OC | FETHA_OC | OTW | OTSD | PVDD_UV | GVDD_UV | GVDD_OV |
the main part of my schematic is
I tried to change the pump capacitors with one 200nf but nothing. I tried both MK3 and MK4 firmare version.
NIKTEN96
Anyone can help me? Because i think the schematic is right, but the problem remains.
Craig_Gault
Any progress on this issue?
I am having the same problem with my custom mk4 pcb.
CGault
