Flipsky 75100foc motor detection sensor issue fails every crysaltemotor I've tried
Wheelzscootersinc
I have a vintage ebikes with mods
  1. Flipsky 75100foc controller
  2. Crystalyte the crown 8000w motor
  3. 20s (2 10s packs in series)
Now I have tried running detection on this motor and a few other crystalyte motors and every time the motor detection fails due to sensor error andi know for  a fact the sensors are fine as each motor runs on other controllers fine. I am at my wits end and about to go and blow up the controller if I cannot get some help on this and I'm stck with this controller for this build please help I've tried adjusting many diff motorsetings ad when I try to detect resistance and insurance it fails to do so as well so im at a loss forwhats wrong I'm not extremely technical with vesc but I own a shop and do e scooter builds and repairs for a living. Normally I would opt for a sabvoton controller but this build can't have such a large controller
tom355
Your wiring is ok? Did the controller ever work with one motor?
On huge motors, run the detection with much higher amp rate.
Please report the results her.
I am also having a hard time making a gmac run. Even after the R/L/I detection and Hall sensor tabel detection it runs horrible.
Rising amps and reducing ERPM was a massive step forward but still lightyears away from running good.
