What do the LEDs mean?
Chaim Lukas Maier
I am new to VESC and using a FSESC 4.20.
I cannot connect to it via USB anymore. (It worked until a bit ago.)
The LEDs show:
- Blue: Permanently On
- Green: Off for 1 second, On for 1 second.
- Red: On whenever Green is on
Is this a special (intended) mode, or did I break something?
Are the LEDs trying to tell me something? (Also, where would I look this up?)
Thank you,
Chaim Lukas
Blue = ON
Green dim = software running
Green bright = driving
Red = fault
Something is not OK with the controller. USB should work. You can try and re-flash the firmware via SWD. If that doesn't fix the issue, you have a HW damage.
